Ac bracket need help asap!!!
Discussion in 'HYBRID -> EG-EK / DC' started by jdm2envy, Aug 16, 2010.
  1. jdm2envy
    jdm2envy New Member
    tdot
    hey guys, i have a 99 civic and im swapping a b20 non vtec motor, my question is do i the ac bracket even if im not putting my ac compressor? If so can i use any b series ac bracket or just the delsol vtec and crv ones.. thanks!
  2. Briansol
    if you'r enot planning to have/use a/c, you don't need to mount the compressor to the motor, thus no need for a mount.
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Well, you need the mount, you just don't need to make sure your compressor can bolt to it. The AC bracket is also the front left torque mount, you need it, unless you're using something like Hasport motor mounts, their strong enough to hold without them.
  4. lemontit
    lemontit New Member
    Lyman, Me USA
    Yes, you do need the Left torque bracket even without the AC, and I've read before all B series have that same bolt pattern for the bracket. the only thing I would check with your seller is the length of the stud on it.
