accord header ?
Discussion in 'Accord' started by need2bfaster, Dec 19, 2007.
  1. need2bfaster
    need2bfaster New Member
    pa
    im not 100% sure but i think i saw a dc header on an f20b4 engine at a junk yard the guy said like 100$ i can have it does any one know if it will fit an f22a1 or are the ports spaced diff?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    not sure but im sure you can get a new one on ebay for cheaper
  3. need2bfaster
    pa
    a dc header for under 100$
  4. AHHVTEC
    Alabama
  5. need2bfaster
    pa
    i got an ebay one liekthe whole exhaust i heard that the they crack
  6. AHHVTEC
    Alabama
    they can but i think id chance it rather then buy a used dc
  7. need2bfaster
    pa
    true and thanks ill justt stick to the ebay header i have now then
  8. AHHVTEC
    Alabama
    lol do you already have a header on your car
  9. calmfornow
    calmfornow System Failure Racing
    Zionsville, pa
    take em
    F22a1 and F22a4 will work. If i were you i would grab them and run. cheap price and when u take them off and if they are not smashed up or cracked you will be fine, so ur answer is yes
  10. need2bfaster
    pa
    yeah i got an ebay header on my car now i asked about the dc header cause mine started to get loud so i thought it was cracked here i looked and the nuts vibrated lose and thats whyit rattles so ill just stick with the ebay header
  11. BrutalB83
    Rochester Hills, MI
    Did you torque the nuts to spec when you installed the header? That's wierd that they came undone. If it's been like that for a while you might want to get a new gasket and then use a torque wrench to tighten the nuts down to the proper tightness.
  12. Uncle Buck
    Uncle Buck JDMDecals.com guru
    Spearfish, South Dakota
    all the F and H series motors are exactly the same block casting....
    but the heads are different.....
    H23 and the F22 use the same bolt pattern....
    H22 and the F20 use the same bolt pattern...
    those are the only combos you can use
  13. need2bfaster
    pa
    i blew a gasket and thats how im guessing they came lose
