accord swap
Discussion in 'Accord' started by beaner8390, Dec 4, 2007.
  1. beaner8390
    beaner8390 New Member
    would it be posible to swap a k24a2{tsx engine} into a 1995 dx accrod..with a 5 speed transmission
  2. BrutalB83
    Rochester Hills, MI
    Yes, it's possible. It won't bolt up to the Accord's transmission though. You'll need a K-series transmission as well as just the motor.
    Check out Hasport for the mounts you'll need: Hasport Performance, Inc.
    The mounts are on the front page. They are kinda pricey though, but unless you can fabricate mounts yourself than they're probably your best bet.
  3. XB-70
    XB-70 Po Boy's Special
    NC
    im looking to do the same in my 93 SE, is there any advisories against this, i like the power output, but is there a better choice or reasons not to ?
  4. BrutalB83
    Rochester Hills, MI
    Well, it requires custom mounts and lots of wiring. An H22 will drop in, bolt up, can work with your stock tranny, and will be easy to wire in, plus it makes 200 horsepower right off the bat, where as those new Element/Accord motors make 160 in stock form. You can swap a different head or just swap the TSX motor instead and make good power, but you're looking at a lot of money for all of that.
