accord what obd ?
Discussion in 'Accord' started by AHHVTEC, Jul 29, 2009.
  1. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    im needing to know is the 90-93 accord all the same obd ? i was thinking the 90-91 was obd0 and the 92-93 obd1 but im not so sure. the accord is the odd ball when it comes to that.
  2. Hondadude141
    TX
    90-93 were all OBD 0 and it changed to OBD I in 94 with the intro of the F22bx series engines, all of the f22Ax are obd0
    1 person likes this.
  3. AHHVTEC
    Alabama
    cool good to know. the prelude is what was throwing me off i think there obd1 started in 1990
  4. Hondadude141
    TX
    yeah, the prelude was a little weird
  5. nootrac22
    exeter pa
    I had a 93 and it was obd1
  6. Hondadude141
    TX
    a 93 prelude or accord? I have never heard of an f22a2, f22a4, being OBD I
  7. nootrac22
    exeter pa
  8. AHHVTEC
    Alabama
    confused again lol
  9. nootrac22
    exeter pa
    anyone else wanna chime in on this??
  10. calmfornow
    calmfornow System Failure Racing
    Zionsville, pa
    All of the accords are obd1. They stopped obd0 on the accords in 89. I am 100 percent on that. 90 and up are obd1 untill 96
  11. Hondadude141
    TX
    huh, well time to update my little info sheet, because its definitely wrong then, Thanks man!
  12. calmfornow
    Zionsville, pa
    Not a problem. The easiest way to determine if a honda is obd0 or obd1 is that they both have to be made before 96 and obd0 had an led on the ecu itself to check for code and you will see it blink and that is how you get the check engine light code. And obd1 you check the check engine light codes on the dash. Also on the 90 thru 93 there is a wire clip on the passabger side right under the glove box that is not connected to anything and has 2 wires going into it. Jump those 2 wires together and your check engine light will blink your code sequence
  13. AHHVTEC
    Alabama
    so if its a obd0 it will have the led light on the ecu like the civics, but you have to jump a wire to get them to count like a obd1 ecu, correct ? if so thats weried because on civics that are obd0 you just turn the key on and they count
  14. eg6sir
  15. AHHVTEC
    Alabama
    oh read that and i even sent b a pm on it because some of the stuff im not that sure is correct but he said he didnt do the list so he was not sure either.
  16. nootrac22
    exeter pa
    yes but my stock 93 accord was OBD1, and the jumper was on the passenger side under(kinda along side) the glove box. Jump it and the CEL would flash on the dash.
  17. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    My 1990 Accord had OBD1 connectors too; and an OBD1 ECU as I was using the ECU in my Civic that has been converted to OBD1.
  18. eg6sir
    :shrug: .. i always thought 92-95 was obd1
  19. Hondadude141
    TX
    in 94 I know they switched to OBDI on the accords, and that little engine sheet is where I got my info from... soo.... yeah....
  20. mclovinF22
    mclovinF22 New Member
    90-93 accords are all obd1
