Advice on running problem with 88 S10
Discussion in 'Other Vehicle Discussions' started by Jdubspeeds, May 24, 2004.
  1. Jdubspeeds
    Jdubspeeds Senior Member
    Tacoma Wa
    When its cold it runs perfect, when its warm it doesnt want to start. It cranks, has spark, It appears to have fuel. This is a TBI model. I just put new spark plugs and fuel injection cleaner to see if I was fouling my plugs. When I took them out they appeared black with soot. Anything else I should be looking for? I was thinking maybe its the fuel pump? When it doesnt start when its acting up like this if I floor it, it will barely run. Then after doing that for a bit I can rev it up fine in nuetral. When I drive it underload it spits and sputters and doesnt wanna run right.
  2. brian11to1
    brian11to1 Senior Member
    fuel filters/pump?
  3. tlb1127
    tlb1127 Banned
    88 S10 Truck?????????? Confused if your asking about a truck or honda???
  4. BigJ
    Weird....
    What motor's in it? The 2.2l 4banger, 2.8v6, or the 4.3l v6?
  5. driverunknown
    driverunknown Senior Member
    o2 sensor?
    Timing?
    I don't know man bump!!!!
  6. turboB20hatch
    turboB20hatch Senior Member
    pacific nw
    2.2L 4 banger... and yes its a s10 TRucK
    as long as u sell it while the motors cold it should be fine.
  7. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    wrong section, non honda tech goes into Other vechiles
  8. pissedoffsol
    does it have a MAF? thats a typical problem of a dirty maf
