Yesterday I hooked a air fuel meter to my lsvtec and it is running rich. When I measure the voltage from the o2 sensor it is .76 volts. should the voltage measure .49 for a proper air fuel ratio? I am considering buying either the HKS super AFR or the split second to adjust this with. I have an idea to hook up a rheostat in the o2 sensor voltage signal line to adjust this to .49 volts. Would that work since the fuel is based on the voltage signal, has someone tried this. My ecu is a chipped p28 and it is laying the fuel on.
Thanks, Kevin
Thanks, Kevin
