Annoying sound... HELP!
Discussion in 'General Tech and Maintenance' started by Vosty, Aug 31, 2006.
  1. Vosty
    Vosty "REP 4 U" Whore Member!!!
    Lower Valley, WA
    So I finnaly swapped in my second b18c this time a fully built engine but there is a annoying loud pitched sound coming from what seems to be by the air intake. It didnt make this sound before and its not the wistling sound commonly heard from most b16's b18's with aftermarket air intakes. The other thing that is weird/annoying about it is that you can hear it only at a certain rpm (and pedal has to be pushed down to hear it) so if i control the throttle it will make this noice conistantly im going to go attempt to record the sound for you guys. My tranny also makes a noice that i thought was a throw out bearing but is not because i just replaced the flywheel. Its very annoying and i want it to go away!!! ahhhhhh...Help! Could it be from the intake manifold or by the throttle anywere?
    Thanx guys...
    Video up shortly of the sound... "Reason im not giving the car a lot of gas because im breaking the engine in it only has 80 miles on it and the sound doesnt come at higher rpms...
    Click the Link below <>
    Vosty's Annoying High Pitched Sound HELP!!! - Poor Quality
    Vosty's B18C-High-Pitched-Noise-High-Quality -
    I guess it could be the intake what throws me off is how it only does it when the pedal is in so far or certain rpm one of the two not sure...
  2. Vosty
    Lower Valley, WA
    My car is running uber lean because of a chipped p28 gone wrong... im alrdy aware, i have the s300 hondata ordered... And will go in after I break in the engine... And sry i reduced the quality so it wouldnt take forever to upload / load... Going to try getting a lil higher quality smaller clip... Its actually quite loud in the car/outside... Listen closely...And the slapping noise somehow got on there wtf its not the car... lmao... its prb just reduced quality annoying sounds...
  3. lil_red_rex
    lil_red_rex i do body work!
    west have ct
    dude.....wtf.......the noise is ur intake sucking air!!!!!!!!!!!!!!!!!!!
  4. girls_are_mean
    girls_are_mean New Member
    utah
    Sounds to me likes its coming from your intake too, but i've never heard a intake that has a high pitch whislte noise and certian rpms. by whistle i mean like a pinhole in an exhaust and it has that stupid ass noise like your holding a peice of paper tight between your fingers and your blowing across it really hard
  5. Vosty
    Lower Valley, WA
    I took the intake off and tested it its actually coming from the skunk 2 intake manifold weird? and im guessing there isnt a fix for it... booo buy a new one... thats my fix grrrrrr
  6. Vosty
    Lower Valley, WA
    Problem Fixed i swapped out to my old throttle body and the noise is gone... crazy eh?
  7. TurboMirage
    throttlebody gasket?
  8. cashen
    cashen Junior Member
    Oregon
    Oddly enough I have this exact same problem with a skunk2 intake manifold with B18. Whistle happens at certain rpm's and throttle positions. I'll try replacing the gasket and see what happends.
  9. eg6sir
    the skunk manifold makes the whistling noise.. its normal
