Vosty
"REP 4 U" Whore Member!!!
So I finnaly swapped in my second b18c this time a fully built engine but there is a annoying loud pitched sound coming from what seems to be by the air intake. It didnt make this sound before and its not the wistling sound commonly heard from most b16's b18's with aftermarket air intakes. The other thing that is weird/annoying about it is that you can hear it only at a certain rpm (and pedal has to be pushed down to hear it) so if i control the throttle it will make this noice conistantly im going to go attempt to record the sound for you guys. My tranny also makes a noice that i thought was a throw out bearing but is not because i just replaced the flywheel. Its very annoying and i want it to go away!!! ahhhhhh...Help! Could it be from the intake manifold or by the throttle anywere?
Thanx guys...
Video up shortly of the sound... "Reason im not giving the car a lot of gas because im breaking the engine in it only has 80 miles on it and the sound doesnt come at higher rpms...
Click the Link below <>
Vosty's Annoying High Pitched Sound HELP!!! - Poor Quality
Vosty's B18C-High-Pitched-Noise-High-Quality -
I guess it could be the intake what throws me off is how it only does it when the pedal is in so far or certain rpm one of the two not sure...
Thanx guys...
