Another IACV thread....
swanny
Who here has successfully repaired their IACV? I have a 95 GSR, had the nasty erratic idle, took off the IACV cleaned the screen and tightened the white ring that threads inside of it. Now a month later it is back. Any ideas? links?
TIA.
Been there, done that. Thanks anyway.
If you have been there and done that then the wax valve inside has gone bad...get a new one.
My buddy I worked with at Honda postponed his IACV for a night. That morn. he was downshifting to a 4-way stop and the idle surged....launching him and his pristine teggy into a truck. They are worth the $... :D
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D I have a guaranteed BYPASS Plug in & Go fix that will make you scream as loud as I did when I figured out, tested and solved the elusive IACV CEL mystery.
Guaranteed.....No bull.
Interested?????
