auto b18b1 into eg mount help
Discussion in 'HYBRID -> EG-EK / DC' started by cvacjohn, Jul 4, 2010.
  1. cvacjohn
    cvacjohn New Member
    engine mounts arent lining up. what is the proper mount combo? driver and rear line up but the passenger mount is bout an inch off to the left. any help is appreciated
  2. lostsoulzprophet
    lostsoulzprophet delslow
    georgia
    what mounts are you using. that would help a little.
  3. cvacjohn
    cvacjohn New Member
    just the stock mounts. i thought it was bolt in but its off
  4. lostsoulzprophet
    georgia
    i know on my car with my b18b1. i have aftermarket mounts on the sides stock civic ones on the bottom front and rear is combo of civic and integra.
  5. 95EGCoupeVtec
    95EGCoupeVtec SOHC VTEC at its best
    South Mississippi
    you have to use a automatic integra LS mount for the tranny mount for it to work. what rear mount and bracket are you using?
  6. cvacjohn
    cvacjohn New Member
    the ls auto mount is too wide for the eg bay. it hits the passenger side which then pushes the belts into the driver side. so i got a budy to fab a mount with square tubing that im going to cut out the old mount bolt slieve and urethane the slieve into it. will this work? given that its lined up. will the urethane hold?
  7. dateg513
    dateg513 New Member
    cincinnati
    use civic mounts
  8. dateg513
    dateg513 New Member
    cincinnati
    and you dnt need two lower front vib mounts
  9. 95EGCoupeVtec
    South Mississippi
    do you know that the stock auto tranny mount from the civic will work on the b series? i need to know also bc i'm doing a gsr auto swap in my wife's civic.
  10. mntlkase
    mntlkase Local neighborhood prick!
    New Orleans, La
    hmm thats a good question. with 5spd transmissions the stock civic mount works, but auto, hmmmmm. I'm willing to bet a da auto integra mount will work. i have one here, and it looks a lil skinnier than all the others.
  11. cvacjohn
    cvacjohn New Member
    the auto civic / tegy mounts are the same. 93 civic cx and 94 tegy rs i got. where the tranny hits the passenger side, is it ok 2 hammer it out the way? or do you have 2 cut it out and weld in a new piece ? only needs a half inch more room
  12. 95EGCoupeVtec
    South Mississippi
    you can hammer it out i would think. you have to do the same thing on a EF swap when putting in a B series, but on the alternator side frame rail. can you post a picture of where it's hitting and where you want to hammer it out? i'd like to have a head's up of where i need to do it at.
  13. marklyerly
    marklyerly New Member
    Why not just switch it to a manual the swap is very easy the hardest part is taking the pedals out because you need to be a Chinese contortionist to get up in there. :)
  14. 95EGCoupeVtec
    South Mississippi
    bc that's not what the OP nor i are trying to do. if you don't have input on what mounts to use for the tranny side on a auto B series swap or anything encouraging, then please don't post this silly " just swap it to a manual" bs. some people don't want to drive a stick shift. my wife learned on a stick but she wants to keep her civic auto also and do a swap. sorry but i get tired of people saying that. i'm not trying to sound like a d**k or anything...
    On a plus note, cvacjohn did you get a chance to take any pics or find out anything else?
  15. marklyerly
    If I remember correctly the integra mounts should fit properly. It is a tight fit like a shoe horn but it should work. Worst case you could go to Hasport and get a swap kit made to fit like a glove :)
  16. cvacjohn
    cvacjohn New Member
    guna get 2 er this weekend and will be sure 2 post some pics. as 4 that tegy mount fit, it doesnt, and i couldnt find after market auto 2 auto mount. not sure if that exist.
  17. 95EGCoupeVtec
    South Mississippi
    so is it completely custom? if so, is there anyway you could make me one? lol i want it to be kind of a bolt in affair.
  18. 95EGCoupeVtec
    South Mississippi
    does Hasport make a kit? that be sweet. i would just need the one mount.
  19. 95EGCoupeVtec
    South Mississippi
    is there any way you can mock up a mount for it and also make me one? i'd would love that. i'll happily pay. i don't have a welder nor have i had enough experience with a welder to make a mount i'd be comfortable using lol.
  20. cvacjohn
    cvacjohn New Member
    i had a budy make it 4 me. i will ask em, but im in canada. so im not sure how 2 get it 2 ya. lol. rained 2day so pics 2maro
