Axel question
Discussion in 'HYBRID -> EG-EK / DC' started by Dark93DX, May 4, 2007.
  1. Dark93DX
    Dark93DX New Member
    B.C.
    In order to use an ITR transmission in my EG I understand I have to use ITR axels, but my question is do these axels fit my hubs or do i have to do some other conversions?
    Are all b-series axels the same diameter?
  2. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    You dont have to use ITR axles. Any b series axle that is for a manual hydro trans will work. You will need the half shaft also from the same vehicle. It will work with the hubs you have now, no modifying there.
  3. Dark93DX
    Dark93DX New Member
    B.C.
    The reason i asked is b/c i've heard the 98+ jdm
    ITR uses 36mm axels and the older ITR's use 32mm ones.
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    That's on the outer hub, yes the five lug ITR is 36mm, but as said above any other B series axle will work they are the same.
