axle issues
Discussion in 'HYBRID -> ED-EF / DA' started by monzster, Nov 22, 2006.
  1. monzster
    monzster Junior Member
    i have a 91 crx si with a jdm b16 with a ys1 lsd hydro 5 speed. i am trying to find out what axles go in this setup. i have been told 91 integra axles but that is not the case. the intermediate shaft on the drivers side has a male splined end on it that goes into a inner cv joint with a female splined end on it. the problem i am having (i believe it is the axles) is that when i go into a left curve i get a noise as if i am running on rumble strips. i also notice that when i have the car in the air and rotate the wheels forward the wheels turn right by them selves. i pulled the axles and the outer joint on the right side is very tight. i have only had the car on the road for about 2 weeks and the rumble is not as bad as when i first drove it but i would like to have it right. i am not getting any clicking noise with this and the axles appear to have been remaned or rebuilt. i dont know where they came from i purchased the whole deal as a kit from a guy who couldnt do the project. he says he bought them from a guy in canada but who knows. any help would be greatly appreciated.
  2. monzster
    i find it hard to believe this is a honda swap site and nobody has run into this before.
  3. reikoshea
    Dallas, TX
    sounds like your axles are jacked bro. Might just try and pull them, then reseat them.
    Last i heard, the 90-93 integra axles were the right ones for a b16 crx swap.
  4. Walshie
    Walshie New Member
    just so you know a 5-speed half shaft is manditory.
  5. jlicrx
    jlicrx Senior Member
    Colorado Springs
    94 and up Integra axles is what you need
  6. 2in10se
    2in10se New Member
    Get a half shaft from a 90 integra also get axles from an integra 90-93. Sounds like its a b16 for a obd1 car?? or maybe the tranny is hydro?? You sure you know what you have?? obd0, obd1??? cable, hydro??
