axle problems-b16 into a 91 hatch
Discussion in 'HYBRID -> ED-EF / DA' started by 91_stylin_civic, Nov 30, 2008.
  1. 91_stylin_civic
    91_stylin_civic Member
    New Jersey
    i swapped a b16a into my 91 hatch and i am about to put in the axles and noticed they have tone rings on them. so i call autozone and got the part number for the axles on a 90 integra and they do not match, the 90 integra part number was 8000 or 8001 and the axles i have are 8005. 94 and up integras use 8006 so if someone could help me out that would be great.
  2. red91efhatch
    red91efhatch New Member
    Albuquerque
    So are you asking which year axles to use?
  3. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    wtf are tone rings? are you referring to the abs rings? which trans did you use? if you have anything but the 4spd std model hatch the axles from 90-93 integras w/o abs will fit. just remove the inner dust ring from your steering knuckles
  4. D16SiHatch
    D16SiHatch New Member
    If you an hf or std chassis then you will need Si,Dx, or Da spindles.Then you'll need 90-93 manual integra axles. abs or non-abs doesn't matter. the abs ring doesn't affect anything. the dimensions of the axle does not change between abs/non-abs axles. on the passenger side you can use 94+ teg axles as well. they can be from any chassis trim. abs, non-abs, manual, auto trans; they all work.
  5. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    I used ABS axles on my 91 swap. They both the same non abs dont have the sensor rings. I took mine off....no problems.
    When doing your swap remember to use the drivers side axle that goes with the intermidiate shaft you decide to use. You can use any LS shaft in a civic 90-2000, but you must use the matching drivers axle with it. The passenger side doesnt make a difference. Another thing is the auto b-series and the manual intermidiate shafts are designed totally different and cannot be mis-matched. I recently had a highly reputable local Tuner/Racer tell me they were the same and that shouldnt matter. Last time I stopped in there.
    Manual shaft SK7-J Auto shaft SK7-N
    Be careful and know what youre buying when doing your swaps.....
  6. HATCHET_HONDA
    hobart, indiana
    wish i had that info before i picked up my int. shaft......i indeed got an auto and was like wtf lol
  7. 91_stylin_civic
    New Jersey
    its the j1 tranny and im not sure what axles they are i think they maybe 92 gsr axles, the front hubs are off an 90 integra, they are new axles, they are both the same part number, are the axles the same lenght for the left and right side? i was also told that the 94 and up integra axles were a different but im not to sure on that, the axle splines into the tranny on the passenger side but looked alittle long and tone rings are for the abs pick up
  8. HATCHET_HONDA
    hobart, indiana
    yea they both should be the same length. you need the axles to match the int. shaft. do this and youll have no problems
  9. 91_stylin_civic
    New Jersey
    will the 92 gsr be the same as the 90-93 integra, i think thats what the axles are for, the axles will not bolt up to the int. shaft if they are different right? and is there anything else that i should be aware of with axles issues? thanks for all the help
  10. HATCHET_HONDA
    hobart, indiana
    as long as you get the axles that match the shaft you will have no problems
  11. 91_stylin_civic
    New Jersey
    in the next few days im gonna see if the axle fits into the int. shaft. as long as it lines with the int. shaft i should be good right? thanks for all the help
  12. HATCHET_HONDA
    hobart, indiana
    yea 90-93 tegs (gsr, ls,rs) are the same axle and shaft wise. 94-01 tegs would be a diff length axle
  13. 91_stylin_civic
    New Jersey
    thanks i matched them up to a 91 ls and it looks like the same length, how much of a difference is the 90-93 to the 94-01? can you notice the difference easily?
  14. D16SiHatch
    not sure, although i know the 94-01 axle will only work on the passenger side
  15. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    90-00 Ls passenger side axles are the same, the drivers side must be matched with the intermediate(jack) shaft used..
    90-93 Jack shaft(female end)...use the 90-93 drivers side axle
    94-00 Jack shaft(male end)...use the 94-00 drivers side axle
    Either jack shaft can be used on any B series block, year doesnt matter, but you must match the drivers side axle up with the jack shaft used.
  16. 91_stylin_civic
    New Jersey
    thanks for all the help, i got the axles in tonight so im getting closer to completing my build hopefully it goes smooth from here
  17. oilspot
    oilspot New Member
    Seems like a good place to piggyback this question.
    Do the trans from a b18 and b16 use the same axles and intermediate axles?
  18. HATCHET_HONDA
    hobart, indiana
    b18 and b16 are same axle wise. whatever year the int. shaft is you use those axles. an int. shaft from an auto will not work on a manual trans. it wont bolt up right
  19. oilspot
    oilspot New Member
    sweet. I just found out the ls trans I'm planning to use has a humm in 5th. I know I can pick up axles rebuilt but have to junkyard a midaxle. I found one from a ls one the local craigslist real cheap.
  20. HATCHET_HONDA
    hobart, indiana
    just buy new ones jeeeezzz
