b16 built head want feedback
Discussion in 'Civic and del Sol - EG and EK' started by Wilshire, Feb 14, 2008.
  1. Wilshire
    Wilshire Big WIll
    nor cal
    im about to build my head and just want some feedback
    heres the parts list
    buddyclup spec 3 cams, dual springs and cam grears
    skunk 2 titanium retainers
    Rc 68mm tb and tpye r intake mani
    Port match head to mani
    Skunk 2 1mm oversized valves
    and some mild port/polish work
    cometic head gasket
    so... tell me what you think.
    as far as hp gains i am thinking 20-30 to the wheels, is my assumption correct???
    thanks
  2. Briansol
    stock pistons?
  3. Wilshire
    Wilshire Big WIll
    nor cal
    yea everything else is stock,
    one of my concerns is will my compression drop with those cams???
  4. Briansol
    no.... you won't lose compression with the cam, but the 10:1 compression of the b16 is far too low to make those cames worthwhile. the thinner gasket will net you +.1 or .2 ish, so 10.2:1
    ideally, you want 12.5:1 compression or more for those cams.
    you'll probably lose a ton of power until 5500 or so. and up top make a little more.
    i'd do some pistons while you got the head off.
  5. Briansol
    i also just noticed you're from cali.... how do you plan to get this legal?
  6. Wilshire
    Wilshire Big WIll
    nor cal
    well what cams do you recomend for my setup
  7. eg6sir
    :werd: .. how do you plan on smogging your car??
  8. Wilshire
    Wilshire Big WIll
    nor cal
    smog doesnt really matter.
