B16 Ecu On D16
91C-R-X
Can i use a B16 ecu on a D16a6,i read somewhere that some one had done that in i was seein if it is possible
you could, but you would get Check Engine light and all kind of codes for VTEC and O2 sensor - it would revert to limp mode
Always use the correct ECU for your motor. Period.
Yeah but if i could get a B16 ecu to fit onto my D16 i would be able to pull higher RPM's
And what would being able to 'pull' higher rpm's do for you? You realize a D16 doesn't rev up to 8000RPM because in stock form it doesn't make power that high?
Actually, go ahead and put the ecu on there, and spin your D16 up to 8200, and have fun with dropping valves.
