B16 from rex to teg?
Discussion in 'HYBRID -> ED-EF / DA' started by hatukazi, Nov 23, 2007.
  1. hatukazi
    hatukazi ambitious...but rubbish
    Big Lake, MN
    I got an offer to trade shells for a 90 4 door integra, I was wondering if my B16 swap from my crx is a direct drop in, I know I will have to re-wire the VTEC and other O2 sensor but is the wire harness the same? and will my ECU work? also just a guess but I shouldn't have to change axles should I? If this is more than a 1 day job I dont want to mess with it, my wife can keep complaining about 2 seats:D
  2. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    Everything will swap over perfectly fine except for the mount kit and shift linkage. You'll need to use the stock integra mounts and shift linkage. Done :D
  3. 88blacksi
    88blacksi Grandpa
    ? did you cut and weld the shift linkage to fit crx. Cuz its too short to fit LS shell. cuz you cutted it and weld it.
  4. hatukazi
    Big Lake, MN
    then he would need my linkage and mounts for his B18? or diffiernt ones?
  5. 88blacksi
    88blacksi Grandpa
    i have a b series shift linkage uncut pm to see it in person
  6. 88blacksi
    88blacksi Grandpa
    all bolts brackets nuts boots knob bushings are all there LMK
  7. formby
    formby learning in progress
    +1
    O.P, you dont need anything if the teg has the linkage and mounts.
  8. B16RacerN2NR
    Moving back West...
    Jesus, did anyone even read my first post?
  9. formby
    i had forgotten to quote and +1
    FIXED
  10. B16RacerN2NR
    Moving back West...
    :lol: ;)
