B16 Harness Help
Dubkruptu2
Ok, need a little help here. I have a 94 Civic hatch that im putting a B16a1 into. I got this as a short block. So i got a head off of a 2000 Civic Si. Which wiring harness do i use?? Thanks, any help would be apreciated.
modify your stock harness or use one from a 3rd gen GSR or ITR
depending on model you may have to wire for VTEC from the ECU to the shock towers
how do i go about wirring a b16a1 into a 91 integra like what kind of wirring harness do i use
you always use the engine harness from your car and modify it as required - for the most part, harnesses are not interchangeable
some hernesses are interchangeable like the one from 99-00 civic ex to any 99-00 civic dx lx etc... or the one from 96-98 ex to any of the other 96-98 civics..........
