b16 into 92 civic hatch
Discussion in 'HYBRID -> EG-EK / DC' started by DXHatch, Oct 16, 2006.
  1. DXHatch
    DXHatch New Member
    for this swap i have the understanding that i will need everything out of a civic sir engine compartment, is this correct? or is there things i can go without?
  2. tip
    tip Senior Member
    Ennis Texas
    no. do a search because all the info is here but you will be needing b-series mounts, ecu, axles, rad. hoses, and also need to run a couple of wires for vtec
  3. spoon_fed_civic
    spoon_fed_civic New Member
    Missouri
    i read that all candian 92 and some 93 hatchs are pre-wired for vtec just have to get the wiring harness for under the hood
  4. tip
    tip Senior Member
    Ennis Texas
    on the us eg's it is only the 92 and they are only from the shock tower out.........you still have to run a few wires inside to the ecu from the shock tower for it to work
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Actually, they are wired from the ECU to the canon plug, so the wiring is in teh engine bay.
  6. tip
    tip Senior Member
    Ennis Texas
    well not all of them because my personal 92 had some wires in the right place but not all of them...............come to think of it there was only one wire in a17 and that was it....!! but hell your 92 might have had all of them
  7. EG6Civic83
    EG6Civic83 New Member
    I just put a B16A into my 92 Si. It came wired for VTEC but had no Knock Sensor pre-wired. You will need:
    1). Axles
    2). ECU (unless you chip yours for DOHC VTEC use)
    3). Shift Linkage
    4). Radiator and hoses for a 99-00 SI
    5). B series motor and mounts
    You can use your stock harness but if your car does not have VTEC now you will need to run VTEC wires for pressure and solenoid. If you get the OBDI then you will need to also extend the wires for the O2 sensor as the O2 is on the header for your car and is near the catalyst on the B16. You will also have to run wires for the Knock Sensor into D3 on your ECU plug unless you get an ECU chip (like Skunk2 or Hondata) which causes the ECU to not look for the Knock Sensor.
