b16 parts
i have an 89 honda civic dx ... i got the motor mounts. tranny ecu axels.....what other parts do i need to put in the motor.....can i use my stock wiring harness??
I think all you need to do is wire in vtec to the plug going to the ecu. Make sure you have the right obd ecu. If you have the shop manual for your car, check to make sure all the pins on the harness match up to the right pins on the ecu.
:no: !!!!!
You must convert from DPFI (dual point fuel injection) to MPFI (multi point fuel injection). You need a CRX/Civic SI, CRX HF, or conversion (hasport) harness. The one that comes with the engine WILL NOT WORK! You should also replace the spark plugs/wires, the distibutor rotor/cap, the timing belt, the water pump, the clutch, and the tensioner pulley.
Here's some links, DO SOME RESEARCH!!!!
http://www.hasport.com/Tech/Installs/Shopp...20partslist.htm
http://www.hasport.com/Tech/Installs/EFB1.htm
http://www.geocities.com/teampimports/b16a.html
http://tjshondas.20m.com/b16awire.html
http://b16a.honda-perf.org/tech.html
http://www.phatwhippincrx.20m.com/custom.html
(this is a CRX page, but it could help) http://www.honda.co.uk/owner/CRXManual/index.html
...thats all I can find right now.
