B16 Questions
Discussion in 'Engine Building' started by jsnwng, Apr 26, 2011.
  1. jsnwng
    jsnwng New Member
    Recently my SOHC ZC motor blew up. Since I have to get a new motor for my EF Civic I am thinking of going for a B16. Only problem is the only one I can find has an auto tranny bolted on it. I can source a cable or hydro gearbox for the motor but can I simply unbolt the auto tranny and put a gearbox on or will this not work at all?
  2. Magana559
    Magana559 The Warden
    fresno Ca
    Will work perfect. B16 is a b16, auto or stick
  3. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
  4. jsnwng
    jsnwng New Member
  5. jlicrx
    jlicrx Senior Member
    Colorado Springs
    you will also need a flywheel and clutch
  6. jsnwng
    jsnwng New Member
    Oh another question, will i need to change the ecu since it was an autmatic?
  7. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    yes, you need a manual ecu
