b16 swap in 200 civic
hartless
i am doing a b16 swap into my 2000 civic and ive got it all done except for the wiring. going from obd2 to obd1 and the engine wiring harnes doesnt run to the ecu. what harness do i need to finish my swap. and do i need to get a whole harness for the whole care or is there a conversion
moved to the correct forum, you should get much more help here.
check rywire.com for the correct jumper harness to go obd2 to obd1.
makes it a plug and play and much much easier. they should have everything you need.
undr8d, calm down man, no need to suggest sterilization lol.
good luck.
