CRXproject
Hello i did the b16a swap into my 89crxSI and it seems that the reason i cant get it started is because fuel is not delivering into the block. i Change the main relay and the resistor box. The computer is a pr3 and its throwing a code 8 so it works. the only way i can get it started is by putting fuel in the inside of intake manifold and it will run until that is al burned up. I have spent many nights up trying to fix the problem its enough to lose my head i need help please.
