B16a In 89 Crx
Discussion in 'HYBRID -> EG-EK / DC' started by stud4u2c17, Feb 15, 2003.
  1. stud4u2c17
    stud4u2c17 Senior Member
    I juss got an 89 CRX, and I was wondering if i got a full swap of a B16a engine in it, how hard it would be to convert to it... and approx. how long will it take, like is it a weekend job or 2 weeks or so... and what would I run in the quarter, with stock specs. 160hp and 111lbs/tq... like around what... would it be 14's? 15's? or what... well thanks for your time
    TJ
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    No one can really tell you the 1/4 time,too many factors,but I can tell you it is a fast little mother in that car.
    It is pretty easy,there are a couple mods to the engine bay that take a few minutes or so.You can get eveything you need from say,HAsport,and plan it well,it shouldn't take more than a couple days.It also depends on the model,as you may have to convert the fuel delivery system.
  3. ekPhred
    ekPhred Senior Member
    the power:weight ratio would be dope on that car even if it is a b16
    peace!
  4. paybac4223
    paybac4223 Junior Member
    Oside Cali
    well if you are not completely changing all of the necessary thing like the clutch/timing belt, alt, starter and what not then.. you may want to allow yourslef 2-3 weeks of down time in case you fire it up and run into any issues
  5. lilthom
    lilthom Member
    Newport N.C.
    Which models do you have to convert the fuel delivery system?
  6. kyleirwin
    kyleirwin Retired OG
    Vegas
    the dx i believe. i'm pretty sure the dx has dual point fuel injection and you need to convert it to mpfi, which is what the hf and si have.
  7. hybrid invasion
    hybrid invasion Junior Member
    the only model that you have to upgrade the fuel delivery system on is the DX(mine). That model has dpfi, and needs to be converted to mpfi, and requires an injector resistor box which can be acquired out of either the HF or SI.
  8. cerx
    cerx Junior Member
    I own a 91 crx hf and im swapping in a b16b. FOr my swap all i have to do is get the motor mount kit (placeracing.com) mount the ecu, runs the wiring harness and change a couple of things around. my friend did the same swap and it took him about 4 days with help from me. Just incase allow yourself about a week and about 100-300 hundred dollars for stuff you will need.( new hoses belts etc.)
