b16a n/a VS b20vtec n/a
Discussion in 'Civic and del Sol - EG and EK' started by egycasper, Oct 3, 2009.
  1. egycasper
    egycasper New Member
    hi
    advise plz
    i don't want to turbo or any boost or raise the bore of my engine.
    what do you think this is my set up:
    i have a jdm b16a engine and i bought these stuff
    68m th-skunk2 pro manifold-skunk2 pro stage 1 cams-pro gears-4.7 final gear ratio-
    4-2-1 tri-y big tube header 2:5" collector-10.75:1 cr wiesco pistons for b16a.
    i didn't put it togethar yet because i think i need more tq and hp so i want to put a b20b block and but a stroker kit full balanced (84m * 89m) light weight kit or (84m * 92m) forged full balanced stock weight with high cr pistons.
    with this head modes and do some head work port and polish
    what do you think?
    advise please
  2. reikoshea
    Dallas, TX
    i wonder if you can trade your 81mms for 84's since (im hoping) they are still new in box. A little port work to the b16 head couldnt hurt.
    i think you're on the right track as long as you can afford about 2 months of downtime on the car (a rough guess about what that kind of time that work will take).
  3. egycasper
    ok
    but light wieght full balanced stroker kit or forged full balanced stock weight ?
  4. 78civic
    78civic Junior Member
    NW MS, Y'all
    What r u going to be doing with your setup?
    Which ever you choose, Lighter=spin faster, longer than heavy without damaging things..
    E
  5. egycasper
  6. reikoshea
    Dallas, TX
    scat eagle and crower are all very reputable names in the world of automotive parts. you shouldn't have any problems with those parts.
  7. egycasper
  8. reikoshea
    Dallas, TX
    whats the point in that when you can just get an LS crank?
  9. egycasper
    all kit balanced with every rotating assambely
  10. egycasper
    problem please
    are eagle ,crower,..... cranks are balanced and what should i do after i put the rods and the forged hc pistons together...
    it's not stroker kit but i'll buy crank eagle , rods eagel , bearings and pistons separately.
    do i have to go to doing balancing to this compination?
