B16a build help
Discussion in 'Civic and del Sol - EG and EK' started by ek4sirtrini, Oct 2, 2012.
  1. ek4sirtrini
    ek4sirtrini New Member
    Hey. I was searching the web for tunning my b16a and bumped on this site looking for help... I was reading alot of post and don't know if you maybe able to help me with this build that i have accomplished. I'm from Trinidad an Tobago and would really like to get some info or help from you guys.... So this is what I've done
    Car: EK 4 SIR
    Mods on engine
    CP Pistons 12.5 compression Ratio
    Manley Rods
    Arp Bolts top/bottom/head
    Cometic head gasket
    Skunk2 Stage 2 Cam Gears
    Skunk2 Spring valve springs/titanium retainers
    Skunk2 Pro Series Intake Manifold
    Skunk2 70mm Alpha Series Throttle Body
    Skunk2 Adjustable Cam Gears
    MSD Pro-Distributor Cap
    MSD 8.5mm Spark Plug Wire
    MSD Ignition Coil
    Stock Injectors
    DC Sport Extractors
    3" aluminium pipe with 18" length and K&N filter
    B18c Type R L.S.D gear box
    ACT Extreme Pressure Plate With Stage 3 Clutch
    9lb Flywheel
    ECU: Stock Brain with Greddy E-manage Ultimate
    Full Energy Suspension Bushings
    KYB GR2 Shocks & tein Springs
    Few Braces top/bottom ETC
    4 wheel disk Brakes
    Stock Brakes
    Steel Braided Brakes Line
    Hawks Pads
    OK this is what I remember for now. Every thing is on the car hooked up Stock Nothing Touched or tuned but car is running... few times took it for some runs and it had impressed me cause i did some few races and beat b18c,STI,RB,SR ETC. Problem Was I didn't had time to spend on car because of job. Now things are OK and looking to get back on track cause I know the car has some potential. Tanks
  2. serrilion
    serrilion In my own little world! VIP
    I would check in to Neptune, Crome, or even looking into a hondata S300 ECU were u can tune the car yourself. Just an idea for u, the E management is OLD, and I used it for my prelude, also caused it to blow up... just some food for thought
