b16a o2 sensor placement???
Discussion in 'HYBRID -> ED-EF / DA' started by jason22ga, Apr 19, 2007.
  1. jason22ga
    jason22ga jason91si
    griffin,ga
    does anyone know what o2 sensor goes where on a b16a stock exhaust manifold theres 2 holes side by side where the sensors go but i dont know which sensor goes where i know one has a green plug and the other has a white/clear plug so i need to know which on goes on the driver side and which one goes on the passenger side
    thanks
  2. invisibledemon
    Tn
    i believe that the one with the green plug goes on the passenger side. thats how mine was on the motor when i recieved it.
  3. jason22ga
    jason22ga jason91si
    griffin,ga
  4. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Doesn't matter, it'll work either way.
  5. jason22ga
    jason22ga jason91si
    griffin,ga
    well ive been told that if there switched the car will run lean on 2 cylinders and rich on the other 2
  6. invisibledemon
    Tn
    yeah theres one for each two cylinders. i would imagine that if you crossed them then say if cyl. 3 and 4 ran rich then the ecu would lean out cyl. 1 and 2 bc its getting the reading from that o2.
  7. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    Yeah, it does matter. The problem is that I've heard conflicting things as to whether or not the japanese motors have them switched around on the ECU plug. I've heard that you need to swich them from the way they come in order to get them to work with your stock harness. Honestly I have no clue. I switched mine and it does seem to run a bit better. Perhaps someone else can clarify this.
  8. invisibledemon
    Tn
    ? maybe. its worth a try. im waiting for a new dizzy to hopefully get mine running. but i'll try it and see how it goes swapped.
  9. freak86
    freak86 New Member
    Southwest Michigan
