B16a rev issues.
Discussion in 'Civic and del Sol - EG and EK' started by Jared759, Jul 15, 2012.
  1. Jared759
    Jared759 Well-Known Member VIP
    SC
    Swapped a b16a into my 92 hatch about 2-3 months ago, the car already had a hacked up harness in it, so I bought a z6 harness a few days ago and swapped it in. Now the car won't rev past 6800 rpm. I've tried my p30 and my chipped p28 and I have the same problem with both. I have a CEL, its code 1 for an O2 sensor that is plugged up and was working fine before I swapped harnesses. I've looked over wire colors and made sure all plugs are in the right place. I'm racking my brain on this one. I need some input.
  2. Jared759
    SC
    Just fixed my check engine light. Still having the same problem.
  3. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Hard to say. How did the swap drive before the harness switch?
    Hacked up harness.....did ALL D16Z6 plugs fit onto the longblock? I'm wondering what OBD sensors were on the motor.
    6800 limit is kinda high for a limp mode.....weird.
    Have you driven it After you've made the CEL go away? (wondering if you can get another code from putting a load on the motor)
  4. Jared759
    SC
    The car drove fine, it had a little idle surge once in a blue moon. The motor is good I purchased it from hmotorsonline not to long ago.
    I just finished driving it around, no CEL, not even under load. All the plugs are in the right place according to the diagram I used. Vtec is engaging with both ecus and it pulls pretty good. Its not really like its hitting the rev limiter its like its hitting a fuel cut. I'm going to do a tune up on the motor soon and see if that helps anything.
  5. Jared759
    SC
    Anyone know if the d16z6 only had the intake air temperature sensor on the intake manifold itself or on the manifold and the intake tube?
  6. monotech
    monotech Member
    D16Z6 has it on the intake manifold only.
