B16a Sir I -> 89 Crx Hf
Discussion in 'HYBRID -> ED-EF / DA' started by lownslowneon, Dec 4, 2007.
  1. lownslowneon
    lownslowneon New Member
    Going to be ordering this from Hmotors sometime soon hopefully....
    http://hmotorsonline.com/shop/sc2000search.cgi?what=page&item=30002
    I've been researching and looking around some....
    I didn't find much on the SIR I into the CRX HF...
    Can anyone help me create a check list of what I need to buy to swap this in and conver to OBD 1 as well?
    Thanks in advance,
  2. norcalgsr
    NorCal
    You don't need to convert to OBD1 as that Sir 1 swap is still OBD0. Everything you need comes with that setup except for a couple things that you can get from Hmotors with the engine swap
    Buy the engine mount kit and shift linkage and you'll be good to go. Then all you need to do is wire the VTEC components to your ECU which you can find out how to do on this site by searching for 'how to wire vtec' or look in the reference section.
  3. lownslowneon
    I plan to boost eventually... wouldn't OBD1 be better?....
    I guess I can leave it OBD0 until that time comes though.
    Seems like a very straight forward swap eh?
    Basically order the mounts/linkage w/ the motor and then buy this.
    Rywire - Online Store
  4. norcalgsr
    NorCal
    Yes OBD1 does have an advantage as far as tuning.. and in that case you may want to consider buying the Sir2 swap now and converting to OBD1. That way when it comes time to add boost you won't have to do anything extra. It doesn't change anything as far as the mechanical aspects of the swap just some additional wiring. If you decide to go that route I would purchase an OBD0 to OBD1 ECU conversion harness from Rywire - Online Store and then it's basically the same swap as the Sir1. You just have to rewire your injector resistor box for the OBD1 injectors. The information on how to do all of that can also be found on the rywire site here http://www.rywire.com/store/images/instructions/inst_0to1jumper.gif
  5. hatukazi
    hatukazi ambitious...but rubbish
    Big Lake, MN
    if your crx is an HF I'm pretty sure you will need new knuckles or the axles wont fit.
  6. lownslowneon
    ORLY? :(
    Can anyone else chime in on this?
  7. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    Yes, if you have an HF, you'll need to swap out the knuckles. With the purchase of the complete change over from HMotors, they'll sell you knuckles from a 90-93 Integra for only $75.
  8. norcalgsr
    NorCal
    Yeah you're right I forgot about that issue.
  9. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    if he's in cali theres the smog and carb stuff.
