Ok...motor is in and wiring almost finished...but I have a few questions.
1. The tps was not mounted on the manifold and the gasket got damaged. I need to get another one or make one, however honda usa doesn't carry that part because all the tps sensors are rivited onto the manifolds.
2. I've wired up all the extra wires for the obd0-obd1 conversion with the vtec sensors, etc... However I'm supposed to wire up the knock sensor next to the oil filter on the back of the block...the problem is that there are more plugs on the b18 harness then there are on the b16. What are all these plugs and do I still need to wire up that sensor separately? And if so do I just leave those plugs hanging?
3. The ECT sensor on the b16 is not on the b18 and the conversion harness doesn't say anything about wiring up that sensor... there are no plugs on the b18 harness that plug into that...so what do i do?
Any help would be greatly apprecaited. Thanks
