B16A Swap Questions
Discussion in 'HYBRID -> ED-EF / DA' started by GlassHeadlights, Nov 30, 2009.
  1. GlassHeadlights
    Calgary, AB
    Just so I got this straight....
    You need...
    -Complete Engine
    -Swap Mounts
    -Transmission
    -ECU (in my case, a new chip)
    -Wiring Harness
    -DA Integra Axles
    -DA Integra Drivers Side Mount
    -DA Integra Rear Mount
    -Shift Linkage
    You need to do...
    -Hammer in frame by the "square"
    -Bolt in engine
    -Make wiring harness
    -Hook up all hoses ect.
    -Remove dust caps for Integra axles
    -Cut shift linkages/weld togther (I am too cheap :))
    And what do you do about the exhaust? Does it match up? How about the throttle cable?
    Simplest B16A swap for a EF looks to be a Integra XSi engine because it already has the driver and rear side mounts plus it has the proper axles. This one comes with everything except for swap mounts. I have a OBD1 conversion and a OBD1 ECU.
    http://hmotorsonline.com/shop/sc2000search.cgi?what=page&item=30003
  2. efhondakid
    Akron-Canton, Ohio
    You got it, your running the mini-me arent you? If so wirirng will be plug and play, and I have an extra chip with a B16 basemap if you want it. Its not that hard of a swap, I did one into my EF, it was my second swap (LS into it was the first) Its a weekend project. :thumbsup:
  3. GlassHeadlights
    Calgary, AB
    Yes the mini me. I'm just poking around for now but I do like the OBD1 170 HP B16s.
    So what about the exhaust and throttle cable? Do they work fine?
  4. OGMatt
    OGMatt Not a real OG lol
    vic B.C. Japanada
    for exaust just get headers and 2 inch piping to a muffler in the back. IMO
  5. GlassHeadlights
    Calgary, AB
    No, I'm asking if the mani will reach/bolt up fine to the stock piping.
  6. 94civicturbo
    94civicturbo New Member
    Liberty, IN
    you will most likely need a speedometer cable too, thats what i need for mine for the speedometer to work in my b18 ef, but it also has a gsr trans so you might not need it just be aware of it
  7. efhondakid
    Akron-Canton, Ohio
    The stock B mani will bolt up to your stock exhaust and as far as the speedo cable just swap the VSS.
  8. 94civicturbo
    Liberty, IN
    that might have worked on mine if the guy knew what he was really doin lol
  9. GlassHeadlights
    Calgary, AB
    Alright, thanks guys! Now I know what I'm dealing with. :)
  10. !JDM_EF-9!
    !JDM_EF-9! I'm just EF'n..
    cailfornia
  11. GlassHeadlights
    Calgary, AB
    What does that mean? End thread?
  12. !JDM_EF-9!
    cailfornia
  13. GlassHeadlights
    Calgary, AB
    Internet language is weird.
    Instead if swapping out the VSS I could swap in a SiR cluster. :ph34r:
  14. OGMatt
    vic B.C. Japanada
    I smell a jdm hoe...
  15. bigdogpappy
    bigdogpappy New Member
    need help troble shooting
    i have a 2004 honda crv, and as soon as the engine warms up, and try to press gas it jerks if i push the gas slowly its fine and any help would be greatful
  16. bigdogpappy
  17. 94civicturbo
    Liberty, IN
    start your own thread!
  18. GlassHeadlights
    Calgary, AB
    Yup, I'm addicted. Once I see made in Japan I pop a nut.
  19. OGMatt
    vic B.C. Japanada
    Cream in ya panties
  20. GlassHeadlights
    Calgary, AB
    Ok now /thread. Too far...:D
