Problem # 1
ok so my engine is making a slow clicking noise which you can only really hear when you are inside of the car with the doors and windows shut. It seems like its coming from the throttle/timing belt/head area and I can't seem to narrow it down. When you are outside the car you can barely hear it. So I took off the head and found the timing belt to be a little loose. Re-did this procedure with friend's help and timing is perfect, the dumb noise persists, anyone have a solution to this or had this happen to them before?
Problem # 2
When I try to start the car, sometimes it starts and sometimes it takes multiple clicks of the key to start it. But it starts up everytime. I have a brand new starter and have checked grounds, they seem to be good... what else could I have over looked?
Problem # 3
Dizzy was throwing a CODE 9, had no choice but to replace it and got a brand new dizzy. CODE 9 went away and no engine light yay! Hit VTEC like 3 times to test if everything was working properly and engine light comes on again!!!! this time 3 codes come on, CODE 8 (TDC sensor), CODE 22(vtec pressure switch), and CODE 1(ECM). VTEC still works but very faintly and not as strong. When I turn the car off and on again, the engine lights go off and VTEC kicks in strong again!!! WTF!!! I have a p30 stock and the motor runs strong, doesn't seem to lag or anything. Just these annoying problems if anyone can help I WILL SEND THEM a LAP DANCE FOR CHRISTMAS!!!
Problem # 2
Problem # 3
