Originally posted by dohch22a4@Dec 5 2003, 04:14 PM
There is no difference between a bare SiR and SiR II.
Originally posted by cws13@Dec 7 2003, 12:39 PM
If budget is a concern, I've said this 20 times...go to your local Acura dealer, cruise thier junk pile, find an LS (you will) and ask for it. I've gotten two free LS motors and turned down 3 more last month. They just pile them up and scrap them. They ALWAYS repair GSR and Type-R's because of how much the heads are worth- but the LS isn't worth shit to them. Before you try to have a B16 welded, posted, repair a sleeve etc.- you can totally work over your free LS longblock to accept you B16 head.
Originally posted by 92b16vx@Dec 7 2003, 12:52 PM
But to answer the question, yes there is a difference in the two blocks. The thermostat housing is different.
will it work together if i have everything obd-1 and i get a obd-0 block will the thermostat housing cause problems?
Originally posted by 92b16vx+Dec 8 2003, 11:48 AM-->Originally posted by h1coupe@Dec 8 2003, 05:37 PM
As long as the fan switchplugs in, it's ok. Just make sure when you buy those parts, to get them for that block.
