ok i just bought a 92 si hatch.. and i bought a full b16a2 swap with harness, axles, shift linkage, p30.. any wiring i have to do?.. im sorry guys.. please helpp me out..i just bolt it in?
Quoted post[/post]]
b16a2 from a '00 Si:
Use the b16 axles and shiftlinkage.
Get a 96-98 Integra GSR/Type R wiring harness. (ebay)
Rear mount bracket from a GSR.
Side mount bracket (timing belt side) from a GSR.
Then it drops in.
You can go another route which is:
Get a single cam VTEC wiring harness, cut/paste the plugs, and get an obd1 dizzy injectors and alternator.
(the GSR harness is easier for plugNplay)
[After rereading this post of yours, you mentioned it came with a p30, so i'm guessing you mis-labeled an Sir2 as a b16a2, which most of that won't apply^]
