B16a2 into a 99 civic EX
pimpson88
The Civic Guy
So i bought a 99 civic ex with a b16a2 engine swap. I am having a lot of electrical problems and was wondering what i need to look for and steps in fixing it. All that i really know is that its not idleing right. It will run but i have to keep my foot on the gas otherwise it will die. Also the vtec wont kick in till about 6000rpm. I know part of the problem is there is a leak in injector #4 and when checking engine codes the iec and o2 sensor came up as there were problems. Also is there anything that i might have to wire in for the vtec? Any help is appreciated. Thankyou
what kind of ecu are you using?
the o2 sensor will cause the idle problem as well.
Im not sure what ecu is in there right now but i do have both the obI and OBII. Which one should go in there?
if youve got a p30 or a p2t, those are the ones you should use.
