b16b distributor
Discussion in 'HYBRID -> EG-EK / DC' started by 2b's, Aug 14, 2003.
  1. 2b's
    2b's Junior Member
    are their any difference in the ctr distributor and the stock si?
  2. D See 2
    D See 2 Senior Member
    Baltimore, MD
    as long as they are both obd2 dohc vtec distributors (which they are), i would think that they are interchangeable.
  3. 2b's
    2b's Junior Member
    i left on the si dist. i was just wondering if it would be better to install the stock ctr.
    right now my idle is at about 1200 rpm's. would this lower the idle?
    they are both obd2.
  4. D See 2
    Baltimore, MD
    no, it shouldnt lower the idle. make sure your timing is set correctly (16*) and i'd lower your idle to 850 or so.
  5. 2b's
    2b's Junior Member
    how exactly is this done? lowering the idle i mean. thanks.
  6. D See 2
    Baltimore, MD
    by turning this screw on the throttle body...
  7. 2b's
    2b's Junior Member
    :D i'm heading to the garage now! thanks for your help. B)
  8. D See 2
    Baltimore, MD
  9. khai_tuan_nguyen
    khai_tuan_nguyen Senior Member
    Which way lowers the idle. Clockwise or counterclockwise. I am thinking... lowering it would be tightening it, which is clockwise. right? Do i turn it while the car is on? What if the car idles at 1000 when it starts and then 1500 when it is warmed up?
  10. D See 2
    Baltimore, MD
    wtf, it should be the exact opposite.
    and yes, tightening the screw lowers the idle i believe. and vice versa
  11. khai_tuan_nguyen
    Yeah it should be opposite any ideas?
  12. D See 2
    Baltimore, MD
  13. khai_tuan_nguyen
    Already tried that... nothing... Thanks for trying though. Any other ideas? Anyone have similar porblems?
  14. daddymax
    daddymax Junior Member
    yea my car is like that too.... Only when it's warm though, if it's cold it almost dies.
  15. khai_tuan_nguyen
    What does your car idle at when you start it? And what does it go up to when it is warmed up. Did you fix it? Do you know what the problem is?
