high for running on pump gas like 93 octaine i heard the compression will be to high with CTR piston compare to the ITR i heard. and i don't want to run with race fuel just on regular pump gas like 93 octaine.
So then what was the point of asking which will give you higher hp numbers? You already seem to have your reason for not wanting to run the CTR pistons... That leaves only one of your choices left...
Also, B16b pistons will put a b18c1 at a hair above 12:1 compression assuming you stay with the stock stroke length, don't mill the head, ect...
USDM ITR pistons will put your B18c1 around 10.8:1
