B18 EF swap ?
Discussion in 'HYBRID -> ED-EF / DA' started by EFhatch4, Sep 16, 2007.
  1. EFhatch4
    EFhatch4 New Member
    okay im swapping a B18 into my EF...now im using a B16 harness just because it came with the car. The harness is OBD-0 and i bought a OBD-1 conversion harness..now does anyone have a JDM OBD-0 Wiring harness??
  2. blackice90HB
    blackice90HB Senior Member
    Pensacola, Florida
    WTF are you talking about? better yet, what is your question.
  3. EFhatch4
    EFhatch4 New Member
    wow my bad i mis-typed that..i meant to ask does anyone have a obd-0 B16 wiring diagram
  4. blackice90HB
    Pensacola, Florida
    B18A1, B1, C5, which one are your running? it all makes a differnece. If you are staying OBD0 use the harness you have in your car already.everything plugs up the same, minus the vtec soleniod and pressure switch, just let 'em hang
  5. EFhatch4
    EFhatch4 New Member
    i have a B18a1..i just need to know the wire colors so i can figure out which plug goes..i dont want to get em mixed up.
  6. blackice90HB
    Pensacola, Florida
    oh, its the same deal as the B16, just dont plug up Vtec. Once you get the harness in you really cant mix the plugs up, some only reach as far as where they are supposed to go. Dont worry, its not hard. If you mix ep up, you will get a code. just find out what code is thrown and switch whever it says around. lol, its realy all it is to it.
  7. EFhatch4
    EFhatch4 New Member
    okay..i was going to do that in the first place lol..but ill deff try it out..thanks i appreciate it
