b18a cuts out at 4k rpm
Discussion in 'General Tech and Maintenance' started by pugarex, Dec 30, 2005.
  1. pugarex
    pugarex Senior Member
    kern co. california
    i swaped a 93 ls engine into a 90 crx dx converted to 5 speed. it ran fine for a few days and now when im in the freeway and i go over 4k rpm the engine sounds like it bogs and i floor it when it does it and you hear it rev up slightly and it will not speed up it will slow down kind of like when you downshift but without the high reving. when i let it go under 3500rpm then it will be back to normal unless i go back over 4k rpm but it will be fine if i floor it or change speed constantly. has this happened to anyone any help will be appreciated thanks.
  2. slowimport
    slowimport Junior Member
    i had this exact problem with my crx si and i had to get a ecu, but mine has a D16z6. it runs fine now.
  3. pugarex
    kern co. california
    so my ecu is bad? does anyone know what i have to do to get it ready to go to the ref. in cali.
  4. eg6sir
    just take it how it is... you get a free retest and they will give a list of everything you have to do..
  5. pugarex
    kern co. california
    do i need to go to the dmv first or what is the process?
