b18a1 into 89 hatch
Discussion in 'HYBRID -> ED-EF / DA' started by delsol_racer, Aug 5, 2006.
  1. delsol_racer
    delsol_racer Junior Member
    watsonville ca
    hey im dropping a b18a1 into a 89 hatch and ecu connects to tha connectors do i havr to do ne other wirring? also do i have to put after market motor mounts on it? what all do i have to change plesase help me thanks
  2. brian11to1
    brian11to1 Senior Member
    yes on both counts.
    do a search newb.
    if youre car is a dx or standard you need to wire in the additional injectors and you will also need to extend a few wires.
    Hasport mounts are what most people use, but there are other brands as well.
    serious an LS swap into an 88-91 civic is the most common swap ever done, please do a search on the subject before posting your questions. its been covered numerous times.
  3. bbissell05
    bbissell05 Junior Member
    WHERE??????
  4. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
  5. 1gcvcb18
    1gcvcb18 New Member
    B18A1 into 84 civic HB
    I have everything i need to do this swap except the motor mounts and axles. what else do i need to do to make this a great swap. Which axles do i use. Can I custom make my own motor mounts. What is DPFI to MPFI?
  6. Andrew
    Tallahassee, FL
    USE THE SEARCH BUTTON!
  7. brian11to1
    yea, do a fucking search.
  8. Crack
    Crack Junior Member
