B18A1 Powered '89 Civic HB
Discussion in 'HYBRID -> ED-EF / DA' started by UnlimitedEK9, Jun 23, 2004.
  1. UnlimitedEK9
    UnlimitedEK9 Member
    Boise, ID
    My friend has a 1989 Civic HB that we swapped a 1993 RS motor into, but after the swap we had to custom make an intake, the custom intake we made was made from part of the stock plastic intake from the RS and a short ram that he had from the original Civic motor. Now that he has the money after the swap he wants an actual intake and not a custom one, I know he has to buy the intake for the motor but do you know of any companies that make a hybrid CAI for his setup? I know AEM makes hybrids but I haven't noticed any for his setup.
    Any Help would be greatly appreciated... :)
    UnlimitedEK9
  2. racintweek
    racintweek Senior Member
    Arlington VA
    90-93 teg
  3. UnlimitedEK9
    UnlimitedEK9 Member
    Boise, ID
    What?
    UnlimitedEK9
  4. racintweek
    Arlington VA
    ls the ef and da engine bays are very similar
  5. MugenCRX
    MugenCRX Senior Member
    Thornton CO
    My CRX AEM CAI fit just fine on my LS motor in my 89 CRX... Your friend should be fine with the right intake for his car, just get the 89 Civic SI intake because it might be a bigger diameter to compensate for the larger throttlebody.
  6. UnlimitedEK9
    UnlimitedEK9 Member
    Boise, ID
    Thank you for you help everyone...if you come across new information let me know...
    UnlimitedEK9
  7. 91crx
    91crx Senior Member
    yea all you need to get is the 88-91 civic si intake
  8. brian11to1
    brian11to1 Senior Member
    FYI = RS-LS-LS Special-GS's had the same engine... RS is not the type of engine.
  9. UnlimitedEK9
    UnlimitedEK9 Member
    Boise, ID
    Yeah...I know that...the engine is a B18A1...but I just put RS because thats the trim of Integra it came from...
    Thank you all again for the help...
    UnlimitedEK9
  10. CReX123
    CReX123 Senior Member
    All you need to get is any COLD AIR INTAKE for a 90-93 Integra. I have the same motor in my CRX and i have a 90-93 CAI in mine, Fits Perfect! The chassis style between the 88-91 civic and 90-93 Integra are basically all the same, Most all Parts between both are swappable.
  11. brian11to1
    or an 88-91 CRX Si
