b18b build up
Discussion in 'Engine Building' started by inspecta83, Oct 2, 2002.
  1. inspecta83
    inspecta83 Senior Member
    im building my b18b for about 12psi, i already did my clutch and flywheel and now i am workin on the motor. i plan on doing the valvetrain, pistons and rods and just wanted to know what yall would reccommend as far as namebrands, specs, etc. for these 3 mods and what other mods you think should be next on my list. thanks
  2. pissedoffsol
    dont bother with valve train.
    endyn pistons
    eagle rods
    nuformz block guard
    and hondata
    you will run 12psi no problem
  3. sprfreek
    sprfreek Junior Member
    you don't think an entire ferrea valve train would benefit him? i seriously do .... your going to need part number IC1000 from the ferrea website
    SRP or JE pistions
    crower rods
    aluminum block guard ( you could also weld it on, machine it smooth then machine holes for the water sleve.... but that';s over kill who wants that ??? :) )
    and hondata stage 4b
  4. inspecta83
    well..under normal circumstances i would agree that i shouldnt bother with the valvetrain, but the valves on the motor are screwed up, so i have to replace them anyway, so i'm planning to get skunk2 valves, retainers, and springs. also, i know that the ls motor is not a high rev-ing motor stock, but i was just wondering what i could do in order to make it safe to rev high.
    as for the hondata...i was plannin on getting a 2b
  5. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Why pay 2X the cost of Eagle rods for the Crower name? I would take the Endyne roller wave pistons over either of those listed. Hondata 2b will be sufficient if you know a shop near by with a stage 4 to tune yours.
  6. B16
    B16 Super Moderator VIP
    yay area, CA
    if you're doing all that, you should be able to handle more than 12 psi, drop your CR to like 8.5:1 :)
  7. LSvinny
    LSvinny Junior Member
    what about cams i herd the right cams can spool you up faster?
  8. lsvtec
    Crower makes a turbo grind for the LS, I don't know anything about how they perform. I imagine that many cam manufacturers make a turbo grind for the LS, just do a little looking. The stock LS cams should be a fine starting point.
  9. LSvinny
    who sells all this stuff and that wont jag you around
  10. lsvtec
    I don't know where you could get the cams from, I have never purchased non-Honda cams. You can get Eagle rods and Endyne pistons here.
    EDIT: I am also unsure of the best place to buy a block guard.
  11. PLRacer
    PLRacer Member
    Sterling Heights, MI
    how many psi at the most would u run on b18 with pistons rods block guard and honata?i know i would also need more than that.
  12. lsvtec
    How much boost do you want to tune for?
  13. PLRacer
    PLRacer Member
    im thinking about 15-20. im trying to make up my mind if i should go b18 or b20
  14. inspecta83
    i spent the whole day today lookin for a valvetrain (valves, springs and retainers) for my b18b that was all the same namebrand and i found out that only ferrera and crower make this valvetrain kit for my motor (i think crane does too). since ferrera is kinda out of my price range i was wondering what you guys think about crane since that is the only choice that i have. thanks
  15. lsvtec
    See the post in "What should I swap?"
  16. knowledge
    knowledge Senior Member
    Beale AFB, CA
    Everyone want to know how much psi they can run with this or that! I will say this once! IT ALL DEPENDS ON WHAT SIZE TURBO YOU PLAN ON RUNNING! A TD05-12A@15psi pushes 320CFM's. A TD05/6-18G@15psi pushes 600CFM's. Almost twice as much! You could lets say run the 12A at 10psi safely, but once you swap it for a 16G (that pushes 505CFM's@15psi) you could only run it at 6psi safely. So from now on we need to see X turbo with Y motor! This would help get accurate info!
  17. pissedoffsol
    to my knowledge, crower is the only turbo cam maker for the ls.
    theres even less support for springs/retianers/etc for the ls head. why? its pointless. the ls was no meant to rev in the first place- so why do it? furthermore, why do you want to rev higher with a turbo? shift and make boost again. with the ls tranny, you will be in gear long enough anyway, and there's no vtec range to fall out of.
    if you want more free flowing- focus on breathing- not valbve train. cams, yes.. springs, retainers, no.
    also, if you are doing valves, as you said yours are shot- make sure they are done correctly. you can't just drop in new valves.
  18. knowledge
    Beale AFB, CA
    You should use my post as a pin up b!
  19. slohnda
    slohnda Senior Member
    Sierra Vista, AZ
    crane cams (www.cranecams.com) makes a turbo cam for the ls. its their stage 3 'number #14' cam.
    Turbo applications
    This profile features our unique ”split duration” lobe profile design (exhaust duration is less than intake duration), ”spools” turbo faster for quicker boost/response
    Reduces turbo lag time
    Strong mid to upper rpm range when boost applied
    Use intercooler and low restriction intake/exhaust
    Use new valve springs
    RPM range 1,500-7,500
  20. LSvinny
