allbottledup
I was looking under the hood tonight and found a wire unplugged. Its for the EVAP purge solenoid. So I started looking at the manuals and trying to find things online with no luck. What is the proper routing for the vacuum lines on a boosted b18b? I see that the hose off the BOV goes into a T fitting for the boost gauge and the back of the manifold. I dont know what is supposed to go where and I am wondering if that is causing some of my other problems. The fitting by the throttle body is just plugged. I know on the regular setup the canister is supposed to be hooked to that fitting by the throttle body and goto the evap purge solenoid, then the solenoid to the back of the intake manifold. Any help or diagrams would be great!
