it is b18c5 integra type r motor and trans.. my main concern is can i run the si distributor?? I know the si has a internal crank sensor and the b18 has external sensor. There are some more wires that need to be added, but crank sensor i am not sure about..
I got the same swap ur doin and the 1.6 harness works great on the type r but depending what ecu u run u will need to run the crank angle sensor and/or the knock sensor wires but i use a tuned p28 and didnt have to run any extra wires
