b18c1 into 94 del sol vtec
Discussion in 'HYBRID -> EG-EK / DC' started by 94delsolvtec, Dec 18, 2007.
  1. 94delsolvtec
    94delsolvtec New Member
    im new to this and i want to do a gsr swap into my 94 del sol vtec. i know i will need axles and wiring to do this, but what else is needed for this swap, and will it all bold straight in?
    ( i know i have a del sol and im posting in civic/integra but there is no category for del sol swaps so i posted it here)
    Thanx for the help
  2. EJ1B18C
    EJ1B18C New Member
    if your del sol is vtec you wont need wiring you will just have to add the knock sensor, ever thing else will plug up, but you will probly need to make some wires a little longer. if you use OEM honda part then you will need DC2 mounts and torque mounts, and DC2 axles, DC2 shift linkage, a bigger fuel pump than a OEM civic, radiator hoses , and some other little things.
