b18c1 swap help
Discussion in 'ECU's, Electronics, and Tuning' started by x3m, Dec 18, 2002.
  1. x3m
    x3m Junior Member
    i have a 99 civic cx hb and i bought b18c1 and had it installed last week. rage performance modified my cx harness to fit my gsr motor but didn't convert the ecu connector to match the gsr ecu instead they told me to use the si ecu. will the 99 si ecu work on my gsr? please help
  2. ngq
    ngq Member
    99 means u have obd2b ecu & harness so ur stuck with it .p2t 99 si ecu
    will work but no 2nd intake runner & fuel map different.
    p72 from 99 -01 gsr ecu or adapter for obd2.
  3. x3m
    x3m Junior Member
    i already installed the 99 si ecu but my engine still won't start. the engine is getting some gas and the flow of electiricity to the spark plugs are ok. what did i do wrong?
  4. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    is it cranking even??
  5. wildbillhatchbac
    wildbillhatchbac the OG VIP
    an engine needs three things. . . .fuel . . .spark . . . and compression . . . . . i'll say a prayer for you
