When i did my swap, we screwed up getting the "bitch pin" all the way in. With the in only partially in, I only had 3rd thru 5th. When we got the pin pressed in all the way, the shifter worked fine. The bitch pin connects the linkage to the tranny. If thats not it, what shifter/linkage are u using? You need the teg assembly for it to work.
