B18C1
TechChris
Member
I am new to this room so take it easy on me. I just purchased a 94 B18C1 swap
for my 94 Civic. When I check compression on this engine when I get it. What are good readings to let me know if the engine is in good shape. Also if it is marginal would you recommend putting is new forged pistons and rods, rings etc. or type r pistons. I am trying to put together a good engine without breaking the bank. This motor already has a skunk 2 cam not sure what stage and an adjustable cam gear. This swap also came with a lsd tranny. This motor also has a Skunk 2 intake. If I decide to bore it, can you safely bore .040 that would make it 82mm if I am correct. I would appreciate anyone expertise or advise.
Thanks
Chris
thats a fucking steal. did you get the tranny/ecu/axles too?
anyway, as far as compression goes... its not so much the numbers, as the variance between them. + - 10% is ideal.
180-180-175-190 would be a fine reading
180-20-245-10 would not.
as far as boring... stop thinking American units. convert .040" into mm and see what it gets. as far as going to 82, don't. there are 0 pistons made in that size. 81.5 is the "standard overbore" size for b-series. 83+ requires re-sleeving.
Hi All
I just did a compression test on my B18C1 tested 225,225,230,225 so I guess the block is in good shape. Just wondering if I should spend money on a lightened flywheel while the motor is out. Also any other mods I should do while the motor is out.
Thanks
Chris
Hi All
Well this weekend will be the moment of truth. I am hopefully putting the B18c1 in this weekend. This is what I have so far.
B18C1
Skunk2 Cam
Skunk2 Intake
Stage3 Clutch
RC 310 Injectors
Lightened Flywheel 12lbs
Ractive headers (I know I should have gotten better but I got them cheap)
New Type R Oil pump
New Water pump
New Axels
New Shift Linkage
New Rotors
So far I have spent $3129 for everything. I am putting it all together this week, and I will let you all know how it runs when I get it in.
Later
Chris
good luck going through mcdonalds drive through with that clutch.
