B20 wont start
jswift
Hey guys I have a 90 si and just put in a b20b into it, everything is wired up but it will not start. Lights work and fuel pump primes but nothing else happens. I think I maybe missing some grounds, can any of you give me some info on what grounds need to be where? I have been at this all week and have no clue what to do now. Please help!!!!
make sure that the ground wire at the thermostat housing is connected
yeah that one is good, is there suppose to be another ground right next to it? because I see a whole where you can put on but not sure what its for.
Ok so it turns over now, I guess the ground to the starter was not strong enough. Anyway it will not start and stay on, sounds kinda weird too. A friend said maybe due to bad timing but I'm not sure.
check your distributor because it might be no good i have the same problem. i fixed that like two days ago while i was doing my swap, but now i have another problem where i will turn on my motor it will shut of right away.
