needs aftermarket mounts, hasport or arizona race and machine make good ones.
also will need aftermarket shift linkages.
get a dizzy from a crv.
use the engine wiring harness that came out of your ef, not the b20 harness.
if the engine is obd1 then you will need a obd0 to obd1 conversion jumper harness (rywire) and the jumper harness to convert the dizzy to fit your engine harness. you can rewire the dizzy yourself but the harness is plug and play, no headache.
and its spelled which, not "whitch"
