Best Rods Ls Crank?
Discussion in 'HYBRID -> EG-EK / DC' started by lsvtec hatch00, Mar 19, 2003.
  1. lsvtec hatch00
    lsvtec hatch00 Junior Member
    WHAT RODS WII WORK BEST/FIT ON LS CRANK , SI CTR ITR. AFTERMARKET RODS RE TOO EXPENSIVE.
  2. D See 2
    D See 2 Senior Member
    Baltimore, MD
    i believe itr and gsr rods will work
  3. VooDoo9
    VooDoo9 Junior Member
    Tampa, FL
    Is There That Big Of A Difference Between The Rods? I'm Looking At The Same Thing You Are Rebuilding A B18A Motor
  4. pissedoffsol
    just get eagle rods. they are 350 bucks, if not cheaper brand new
  5. lsvtec hatch00
  6. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    No, ITR/GSR rods still won't work. The rod bearing journal in the ITR/GSR crank is still smaller than the LS.
  7. 2 litre EG
    2 litre EG Senior Member
    so cali
    for all 4 rods the retail price is about 350, you should be able to find it cheaper
  8. D See 2
    Baltimore, MD
    look to spend $300 for a new set of eagle h-beam rods.
  9. lsvtec hatch00
    does eagle have a website?
  10. lsvtec
    Last time I looked they either didn't have a site or it was useless. If you need tech info, any shop that sells those rods should be able to help you.
